Tips voor het tanken!
Voor vragen, opmerkingen, tutorials mbt het motorische gedeelte van je auto, kun je hier terecht. Gegeven adviezen e.d. zijn geheel voor eigen risico! Neem evt. eerst contact op met je dealer (ivm garantie e.d.).
Berichtdoor Sportiva-Italia » Za Aug 09, 2008 12:34
bron: World Of Italy
Pumping gas.... more bang for your buck!
Mr. X has been in petroleum pipeline business for about 31 years, currently working for the Kinder-Morgan Pipeline in San Jose, CA. They deliver about 4 million gallons in a 24-hour period from the pipe line; one day it's diesel, the next day it's jet fuel and gasoline. They have 34
storage tanks with a total capacity of 16,800,000 gallons. Here
are some tricks to help you get your money's worth:
Morning is Better
Fill up your car or truck in the morning when the temperature is
still cool. Remember that all service stations have their storage
tanks buried below ground; and the colder the ground, the denser the
gasoline. When it gets warmer gasoline expands, so if you're filling up
in the afternoon or in the evening, what should be a gallon is not
exactly a gallon. In the petroleum business, the specific gravity and
temperature of the fuel (gasoline, diesel, jet fuel, ethanol and other
petroleum products) are significant. Every truckload that is loaded is
temperature-compensated so that the indicated gallonage is actually the
amount pumped. A one-degree rise in temperature is a big deal for
businesses, but service stations don't have temperature compensation at
their pumps.
Don't Load when they Unload
If a tanker truck is filling the station's tank at the time you want
to buy gas, do not fill up; most likely dirt and sludge in the tank is
being stirred up when gas is being delivered, and you might be
transferring that dirt from the bottom of their tank into your car's
tank.
Half Full is better
Fill up when your gas tank is half-full (or half-empty), because the
more gas you have in your tank the less air there is and gasoline
evaporates rapidly, especially when it's warm. (Gasoline storage tanks
have an internal floating 'roof' membrane to act as a barrier between
the gas and the atmosphere, thereby minimizing evaporation.)
Take your time
If you look at the trigger you'll see that it has three delivery
settings: slow, medium and high. When you're filling up do not squeeze
the trigger of the nozzle to the high setting. You should be pumping at
the slow setting, thereby minimizing vapors created while you are
pumping. Hoses at the pump are corrugated; the corrugations act as a
return path for vapor recovery from gas that already has been metered.
If you are pumping at the high setting, the agitated gasoline contains
more vapor, which is being sucked back into the underground tank, so
you're getting less gas for your money. Hope this will help ease your
'pain at the pump'
Sportiva-Italia kan niet aansprakelijk worden gesteld voor evt. onjuistheden, noch voor schade/letsel veroorzaakt door geplaatste tips!
I ragazzi strani che romani!
easyrider
Re: Tips voor het tanken!
Berichtdoor easyrider » Di Feb 12, 2013 22:36
Lijkt wel logica in te zitten maar wat zal het schelen op een tank ?
Zal nog geen 1/2 liter zijn waarschijnlijk.
[url=http://www.alfist.nl]Alfist.nl[/url]
[url=http://www.alfist.net]Alfist.net[/url]
[url=http://www.alfaromeo75.nl]Alfaromeo75.nl[/url]
Berichtdoor Sportiva-Italia » Wo Feb 13, 2013 18:43
Zou t ook niet weten, maar toch; stel dat je n kwart liter per keer zou overhouden met deze tips, dan heb je op jaarbasis toch wel weer n paar liter 'gratis'. Ik heb ook niet altijd de luxe om 's ochtends te tanken, tenzij ik dan rond 05.15 kan tanken (tank altijd bij de BP vlakbij m'n huidige werk). Maar op dat tijdstip zijn ze niet open.. Voor kantoormensen kan het vast wel, maar als je in ploegen zit, is dat niet haalbaar. En onbemande pompen hebben vaak geen Super 98. En met n halve tank, sta ik zo weer bij de pomp :P
Terug naar “Motorisch”
Gebruikers op dit forum: Geen geregistreerde gebruikers en 0 gasten
